4L60 stuck in drive?
Okay, back in January I ended up cracking my tail housing. Didnt get around to replacing it til this week, buttoned it up today. However, it appears no matter what gear is selected (park, neutral, reverse, doesnt matter) the tires are spinning forward. Shifting through the gears makes no difference, I can feel the detents but thats it. The fluid level is back up where it should be, the only sensor that was disconnected was VSS, nothing out of the ordinary happened when I was replacing tail housings. Any ideas what the problem could be?
