How will this stall converter work for me???
as post states, how would a vigilante 3200 stall converter work out for me with a 355 LT1 with a cc306 cam, port and polished heads, Hooker LT's and some other mods a such as 58mm BBK Throttle body, EWP, CAI, 32 LBS injector's, a rebuilt 4L60E trans oh and 3:73 gears. Will this be a sufficient enough stall. I'm using the car on the street so hit me up with inputs and opinions, thanks steve
what are the specs on the cam? i had a vigilante 3000 stall, and it was great. very tight around town, but when you hit the loud pedal, you better hold on. with the 3.73 gears, you could definitely get away with a 4000 stall though. my tranny just took a dump on me and i had to get the converter cut and cleaned, so and i'm going back in with a vigilante 4000.
you won't be disappointed. My advice to you is find someone with a stalled car, and get a ride. Drive it if you can. then pass judgement on a stall.
Precision Industries has a quality product. and P.S. , if you buy a used one it's only $225 to have it re-stalled. pretty fair if you ask me.
See now this is good info to know, So if it grabs out I can send it in and just have it re-stalled, thank you for your advice! Waiting on seller to pm me back!
