No second gear
No second gear
Stock 4l60e with 80,xxx miles, no second gear. Scanner showed a p0752 code, which is the 1-2 shift solinoid. I changed the solinoid and still no second gear. Does anyone have any idea what else it could be?
Yes, I still have 4th gear. The transmission was removed to replace a cracked flexplate. After everything was put back together it worked just fine, it wasnt until about 10-15 miles later that it started acting up. It felt like it was getting hung up between 1st and 2nd and after 2-3 seconds 2nd gear would finally engage. After I got home and parked the car for a while, I had to leave agian and this time there was no second gear at all.
