shift speed on auto trans
Old 05-26-2009, 11:21 PM
411whplt1's Avatar
Default shift speed on auto trans
ok i have a 93 z28 and a good amount of things done, and for some reason my tach dont work and i dont know what speed to shift at. i had it dynoed today and the dyno took 2nd gear to 80 mph buy if i leave it in drive a get on it it will shift at 60 whas going on. all the pple i see on youtube **** 1, 45-50 2, 80-90 so is there a problum. thanks alot for any help.
Old 05-26-2009, 11:33 PM
silverz28camaro's Avatar
1-fix the tack
2-shift points can be adj. in the computer i believe, ask your tuner.
my 4l60e with make the 2-3 shift at 74mph at 6500rpm with 3.73 gears and 26 inch tire.
shift points all depend on your current setup, the Youtube videos you watch wher the car makes a 2-3 shift at 90 is prolly a 2.73 geared car. you need to set shift points according to peak power output, and then go to the track and feel the car out and see if it pulls good or not so good with different shift points.
when i had a 224 cam i gained time from going to a 6300rpm 2-3 shift from a 6500 2-3 shift. the car was just out of steam and need to be put back into the power band.
Now that i have a bigger cam i raised them back up to 6,500rpm on the 2-3 and it felt as if the car liked it better. Its all trial and error, but with your car you may need to fix the tack before you do anything else.
Old 05-27-2009, 12:00 AM
LS1Tech Sponsor
performabuilt's Avatar
93 is not a 4l60e Its a 700R4/4L60 The shift points are controlled by the TV cable presure and the GOVENOR and are actually soley based on MPH TV (THROTTLE PRESURE).
To change the WOT shift points you will need a govenor recalbration kit. Sold by TCI B&M you could also use the corvette govenor which would raise it some. However probably not as high as you would like alone.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 05-27-2009, 01:23 AM
What year did they start the 60e?
Old 05-27-2009, 08:36 AM
LS1Tech Sponsor
The 60e in cars started in 1994 , In trucks 1993
__________________
Call 888-744-6542
Old 05-27-2009, 09:32 AM
411whplt1's Avatar
Ok well when i had the car dyno he took it to 80 in 2nd gear and hit the rev lim, so dose that mean i can **** 2-3 at around 75 with out hurting the motor and yes i need new cluster. Wish i could find some one that will trade the 93 for the 94. Thats whats in my can in great condition but tach dont work. Thanks for all your help.
Old 05-27-2009, 09:42 AM
411whplt1's Avatar
And i think the car need tuned but i cant find any one here that tunes them.on the dyno it put down 301, and 325
