Is my 4l60e going bad?
Old 05-31-2009, 09:41 AM
zracer323's Avatar
Default Is my 4l60e going bad?
So yesterday I go to take off from a stop and it takes a lot more rpms than usual to get the car moving (~1500). Then after getting moving my convertor won't lock up. This is the third time this has happened in the last couple of weeks. What could be going wrong?
Old 05-31-2009, 12:22 PM
therealcreeper's Avatar
in my 93 it'd take until about 2k rpm to get moving on cold starts sometimes. kinda liked it because it was like a free high stall converter. transmission was fine for the month i owned the car. the guy i sold it to has had it for almost a year now with no problems.
never figured out what it was and no one i talked to had any idea either
Old 05-31-2009, 01:38 PM
TA1364's Avatar
Was everything cold when that happen? Did you buy the converter new or used?
Old 06-02-2009, 08:01 AM
zracer323's Avatar
It has only done it while it is hot. I bought the convertor new and have only put about 1500 miles on it.
I figure if something is going wrong it would do it everytime.
Old 06-02-2009, 08:15 AM
LS1Tech Sponsor
performabuilt's Avatar
Scan for codes and look for PO757 if its there have it removed as a test in the tuning
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 06-02-2009, 09:44 AM
tording99Z28's Avatar
As Frank said you are in limp mode. You probably actually took off in 2nd or even maybe 3rd thats why it seemed that way. If you just put a converter in thats the problem for sure. You are throwing either an PO757 or a PO751 code. For some reason its very random with converters on those codes, some people get them, some don't, some get them once and a while and some get them all the time. It happens to people all with different companies converters so its not dependent on that either. Have a tuner remove those two codes and you will be golden.
Old 06-02-2009, 11:58 AM
zracer323's Avatar
Thanks a lot for the help guys. I have HPTuners so I'll try removing that code and see if it works.
