stall ?
stall ?
will this stall work in my car
will i have to tune my car
http://www.jegs.com/i/JEGS/555/60400/10002/-1
# GM TH350/TH400 12" Converter10.75" bolt circle
# Stall Speed: 2300-2700 RPM
that is not for your transmission..
you will not have to tune your car when you get a stall.. it would be ideal to at least bump up the shift points though.
how about this stall
http://www.jegs.com/i/B%26amp%3BM/130/70418/10002/-1
# 1993-96 4L60E V8 (30-spline)
i think so, but could be wrong.. i believe the 95s have a 60e... but that part may not matter.. someone else would have to chime in...
i wouldnt be looking on jegs anyways man..
http://www.converter.com/vigilante.htm
thats my choice in converters.. i would stick with circle D vig or yank.. a converter isnt something you need to go cheap on.... it will make or break your entire setup..
