Clunking Into Drive........... 4L65E
Old 07-14-2009, 09:18 PM
underpressureWs6's Avatar
Default Clunking Into Drive........... 4L65E
i have a performabuilt 4L65E level 3 trans with yanks py3400 converter all with 580 miles on it, i just got a speed density tune last week and noticed the shifts were a little stiffer and it clunks into drive from neutral or park now, what should i do or check???? any help is appreciated!!
Old 07-15-2009, 01:43 AM
LS1Tech Sponsor
performabuilt's Avatar
Well if it happened after the density tune bear in mind several things.
With that set up air flow is calculated not measured the trans line presure uses the air flow to calculate load and affects line presure. So its likley you actual line presure at idle is higher causing the clunk feel
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 07-15-2009, 10:50 AM
will it be fine if i leave it alone, or what do u suggest i do??
Old 07-15-2009, 11:54 AM
LS1Tech Sponsor
If it not really bad should be no issue , Of course I cant actually feel it. If it seems to harsh you could have your tunner lower the line a bit at idle or even lower your idle speed
__________________
Call 888-744-6542
Old 07-15-2009, 12:40 PM
if my tuner can lower the line pressure just a tad only at idle then i'll do that, Thanks a lot for the help!!
Old 07-15-2009, 02:32 PM
LS1Tech Sponsor
Your welcome . Thats what I am here for.
__________________
Call 888-744-6542
