Best shift RPM on A4 with 3.43 gears for 1/4 mile
Old 08-15-2009, 11:56 AM
CanadianEh!'s Avatar
Default Best shift RPM on A4 with 3.43 gears for 1/4 mile
Hi...new to the site so appreciate everone's opinion. I must say I've referred to this site often and have learned a lot from everyone. Here are the dyno numbers on a Mustang Chassis Dyno for my 2001 full weight (3900 llbs with me in it) Conv Z28. Q1. Based on my engine build and the 150 nitrous shot on a 3.43 A4 where should I be shifting for the best 1/4 mile times?
Engine Specs:
Drive Train: Wheel to Wheel Performance Forged LS2-402 Cubic Inches (Callies forged crank, Compstar H-Beam rods, Mahle Forged Aluminum pistons), Bore 4" X Stroke 4" @ 11:1 compression with AFR 225 ported heads and high volume oil pump. The cam is 228 intake 235 exhaust @ .050 and .598 lift with a 114 lobe separation. Custom fabricated stainless steel double cone K&N Cold Air with inlets outside of engine compartment, 160 degree thermostat, Electric Water Pump, Underdrive pulley, Z06 screen-less MAF, Ported FAST 92mm intake and Fast 92mm LoudMouth throttle body, 36 llb injectors and Racetronix in-tank high flow fuel system with 225L/hour Walbro Pump and upgraded wiring harness, Stainless Supermax Dynotech Full length Headers (primary tube 1 3/4" with 3" collector) , high flow cats and Borla cat back. Automatic 4 speed, Yank Converter with 3800 stall and trans-cooler (stock gear ratios but built stronger). Moser 12 bolt rear-end with full Eaton posi, 33 spline axles and 3.43 gear. Tires: Rear: 17" M/T Drag Radials (25" in height). Custom 6 point roll cage built by Jerry Foster.
Power-Adder: Nitrous Outlet 92MM Plate adjustable to 150 RWHP shot. Controlled by V Guage Progressive Nitrous Controller (Dual Window Switch, 1st Gear lock-out, A/F with wide-band, A/F cut-off lean and rich, Heater Controller, Heater Blanket, etc. Safety enhanced with Timing Tuner, Remote Bottle Opener, blow-down tube, purge, FPSW, NGK TR6 sparkplugs and A/F shut-off (wide-band).
Best N/A: 11.84 @ 114.4 MPH
Best Nitrous Pass: 11.21 @ 122.72 MPH
MUSTANG CHASSIS DYNO: (Naturally Aspirated Run)
RPM TQ HP
2863 77 42
2914 82 45
3154 158 93
3865 307 224
4109 328 256
4232 330 265
4354 334 276
4514 339 291
4661 346 306
4779 350 317
4912 350 327
5016 352 336
5137 351 343
5260 353 354
5372 353 360
5465 353 366
5579 352 374
5695 348 377
5787 348 383
5888 346 387
6001 342 390
6065 338 390
6165 333 391
6257 331 394
6335 326 393
6415 320 391
6483 316 390
6545 311 387
6615 306 385
6668 302 383
6720 296 379
6517 285
