Question on a Th400 Swap into A4 GTO
Got the shifter in and trying to get everything ready for the motor Tranny install but not sure what to come off of from the factory harness at the trans for my neutral saftey switch. If anyone has any input on which wires on the larger flat harness that plugs into the trans where the shifting linkage is I would greatly appricate it...Thanks
I am doing the same setup in my 05,tired of those juck 4l65s breaking every month,mine drives I am using the switch on the side of the trans as was on my factory setup,and a manual 400 trubo,with a ratchet shifter,I do need to find out which wires I can use for the back up lights and the speed sensor so my dash works with the speedo.
