4l60e question need an answer
LS1Tech Sponsor
Its certainly not a bad idea to try and get a little fluid in it you will not be able to get it full . However 1/2 to a quart should be fine. Truth is the pump will fill it up instantly on start up . But puttng some in may give a little lubrication for those few seconds and keep you from evacuating the pan on start up
__________________
