4l80E driveshaft/yoke question.
k I read the sticky about this but it didn't seem to clear up to much for me...
just to make sure I have this right for the 4l80E and a 9 inch rear
1350 yoke and U joint, and need a Turbo 400 32 spline yoke, what length driveshaft do I need?
http://www.dennysdriveshaft.com/p102...turbo_400.html
is that the correct yoke?
Chad
Chad
I think that is the right one. I've successfully used the Strange U1650 and the U1664 on my car which has a 9" and a 4L80.
http://www.strangeengineering.net/catalog/index.html
For shaft length, there could very well be slight variance from one car to the next. My car needed a 42" DS, measured from center bearing to center bearing. But you could call this guy:
https://ls1tech.com/forums/member.php?u=79630
Or call Bob at EPP and they can help you out.
Good luck.
Good luck.
