Help! Need Info on wiring and running issue after doing a m6 to a4 swap?!?!?!?!?
ok swapped m6 to a4 and need to know where exactly do i splice the back up lights into and also car starts but will not run for more than a few seconds. Car is an 02, changed complete wiring harness on engine and trans when doing the swap. all help is appreciated and yes, so please dont post the stickies, i have been reading through them for the past 2 hours. thanks Mike
Ok so where in the sticky does it show the c400 connector to which I hook up the light green wire and as for the brown wire it says go to pin connector c200 or 200 in the passenger kick panel but still Jo brake lights even if I have the light green grounded
