Is this possible??????????
Old 09-25-2009, 08:50 PM
boola1341's Avatar
Default Is this possible??????????
Has anyone wanted to be able to lockup your stalled converter when you wanted too instead of the computer doing it for you? Is it possible to wire a switch somehow so I could flip the switch to lockup the converter. At times the converter locks up way to fast. This is just a thought.
Old 09-26-2009, 08:30 AM
calongo_SS's Avatar
Yes you can have a switch, but most only use it for WOT with a multi disc converter.
If it is locking before you want to just driving around town you need to do some tuning.
Old 09-26-2009, 09:08 AM
LS1Tech Sponsor
performabuilt's Avatar
You can put a switch on it however even for that you would have to do some tuning of you would set a code. Best bet is as mentioned to just make some ajustments in tuning to raise the lockup point
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 09-26-2009, 01:36 PM
01ssreda4's Avatar
Very good advice...........
Old 09-26-2009, 06:02 PM
boola1341's Avatar
Ok thanks.
