how long has your RMVB th400 w/brake lasted on the street? (miles)
Old 11-03-2009, 07:56 PM
chasgiv3's Avatar
Originally Posted by slow67
Doing burnouts or pedaling in 2nd?
I made my Son drive it and do a burnout. I'm not sure what he did. Hasn't happened again and I beat the crap out of it.
Old 11-03-2009, 08:37 PM
Restricted User
1BAD_LS1's Avatar
that what im looking to hear guys....
so what gears is everyone running? i have 3.70s right now but thinking of going with 3.00's.....
Old 11-03-2009, 08:51 PM
01FbTaWs6's Avatar
ive got a built th350 with brake. I didnt get very many miles on it before I tossed a rod, but the few I did was a blast! i dont think its very easy to break these things, i was beating on it like it owed me something and it never hickuped once. Run a big plate cooler, and a trans temp gauge, keep the temps down (mine never gets over 180) and you should be fine. Im also running it with an FTI 4400 converter. Oh, and hears where it seperates the men from the boys.........4.10 rear gear
Old 11-03-2009, 09:00 PM
Restricted User
1BAD_LS1's Avatar
4.10 you must turn like 4000rpm at 65mph
Old 11-03-2009, 09:05 PM
01FbTaWs6's Avatar
yeah, its up there forsure. im going to go with a 28 tall tire next spring to help abit. But I love the gear!!!
Old 11-03-2009, 09:08 PM
gsxr1k2's Avatar
Originally Posted by 98Camarod
Pedaling in 2nd gear due to traction issues can be detrimental, especially with a full manual VB with no engine braking.
Well **** ya, liftin is for ******....... Not to mention you slow down your times
Old 11-03-2009, 09:10 PM
gsxr1k2's Avatar
+1 on that
Old 11-03-2009, 09:34 PM
pozesd99''s Avatar
hey i have a rmvb th400 with a shortened 1st gear and 4.11's... top that!!! and a 28in tire
Old 11-03-2009, 09:50 PM
Restricted User
1BAD_LS1's Avatar
lol
are you guys running 1/8th mile?????? you would have to go through the 1/4 at like 9000rpm lol
Old 11-03-2009, 09:56 PM
chasgiv3's Avatar
I use a 3.42 gear. Turbos make plenty of grunt down low. No need to run high gears. Plus if you want to do 160MPH 1/4 mile traps you need some gear left!
Old 11-03-2009, 10:32 PM
Restricted User
1BAD_LS1's Avatar
so you run 2800-3000rpm at 65mph.... thats not bad...
think 3.00 gears are to short? figure with the trans brake i will be able to build boost basically to whatever i want off the line....
Old 11-03-2009, 10:57 PM
  #32
StreetSilverado's Avatar
Glad I found this, I'm going with a TH400 with a brake and 5000 stall. Leaving the 4.33 gears in it so that maybe the bitch will leave HARD .
Old 11-03-2009, 11:05 PM
  #33
01FbTaWs6's Avatar
Originally Posted by 1BAD_LS1
lol
nope, 1/4. But im not turbo either.... Just heads/cam LS1.
Old 11-04-2009, 12:51 AM
  #34
Restricted User
Zero4488's Avatar
I have a full RMVB TH400 4.11's 28" tire and cruise 65 mph at 3k....with a 4400 FTI convertor....top that one.....
Old 11-04-2009, 09:19 AM
  #35
chasgiv3's Avatar
If you can build boost off the line and add enough torque that way I don't see an issue. I definitely wouldn't go below 3.00 gears.
Old 11-04-2009, 12:23 PM
  #36
Restricted User
Zero4488's Avatar
Throw 3.23's in it and call it a day...I just don't think you'll be happy with the 3.00's....
-Dave
Old 11-04-2009, 12:46 PM
  #37
RS_SS69's Avatar
Hunter runs 3.00 gear in his new setup and went 9s on drag radials in a 17" rim size, Zombie runs 10s with a 2.75 gear and he is boosted, Cablebandit runs 9s with a 3.08 gear. Do some searching in the forced induction section and under the advanced searching.
Also what is your rear tire diameter?
Im going with a 3.25 or 3.50 with a 29" tall hoosier slick and a th400, large front mount 20 psi, transbrake and 2 step.
At 70 mph I would turn 2600 with a 3.25 and 2800 with a 3.50 gear.
With 3.73s and that same setup at 70 mph I would turn 3000rpm.
So for your setup lets say you have a 3.70 gear and 28" tall tire at 65 mph you would be at 2888 rpm, not too bad really since your coming from an auto already.
Hope this helps
Old 11-04-2009, 01:01 PM
  #38
Gingervitis Addict
slow67's Avatar
This is what I found in my research:
try to get to 3rd for burnouts, don't let it hook hard during burnout, don't neutral or downshift at end of run, don't decel downshift, and if you do, don't hit the throttle again.
Don't do neutral drops...
Don't run it low on fluid....or with improper shifter adjustment.
Pretty much got all of it. start burnouts in 2nd (unless you have an auto valve body) and get to 3rd as fast as possible.
No pedaling in 2nd with a full manual valvebody (unless you still have the intermediate band)
Dont shift into neutral at the end of a run (or in 2nd with a full manual valvebody) unless you want pieces of a 14lb drum in your leg.
as far as gear, just compare the 1st gear ratio to a glide:
first gear in a glide * 3.73 gears = 6.5648
first gear in a TH400 * 2.65 gears = 6.572
And plenty of people launch fine with a glide.......
Old 11-04-2009, 02:01 PM
  #39
chasgiv3's Avatar
All I can say is I'm really happy with the gearing of my car at 3.42
I have a top speed of 175 on the slicks and slightly under that for the drag radials. I come out on zero boost on 17" drag radials and run 9.35's at over 150 at the track. I can take that same drag radial on the street and feel comfortable that she'll come out of the hole really hard without needing boost. I think a lower gearing wolud make it a bit lazy and I'd need to build boost to come out hard on the street.
Old 11-05-2009, 07:35 AM
  #40
cause4panic's Avatar
Does this mean you cant downshift into 2nd if the wheels are spinning fast or you cant downshift until you are completly stopped? When can you downshift back into 1st?
Quick Reply: how long has your RMVB th400 w/brake lasted on the street? (miles)
