T400 in now no speedo?
Old 12-06-2009, 06:53 AM
INTENESS's Avatar
Default T400 in now no speedo?
Heres my setup switched from m6 car to turbo400 car.My car is a 2001 what do I have to wire up to get my speedo working.Also if anyone knows how I should wire in the reverse lights to come on when in reverse?This is a Hughes RVMB turbo 400 with the hurst quarter stick.Im really liking it since I did the swap man its a blast when the converter kicks in.Should of done this along time ago.
Old 12-06-2009, 07:36 AM
FLT
FLT's Avatar
Take a look at the stickies. There are two ways to do the speedo that I am aware of. The first is to get the correct electronic speedo stuff for the th400 that was used from the factory in late model th400s back in the day. Or you can use an abs wheel sensor from what I have read. https://ls1tech.com/forums/automatic...ransbrake.html
As for the revers lights you will need to get with the manufacture of your shifter to make this happen. In factory A4 cars in the car at the shifter assembly is where the components were. Vince
Old 12-07-2009, 10:04 AM
pozesd99''s Avatar
hook the sensor into the front driver abs sensor, just did it last night. takes all of 5 mins
Quick Reply: T400 in now no speedo?
