TH350. How much weight do I need to drop?
Old 01-19-2010, 12:37 AM
NBMZ/28's Avatar
Default TH350. How much weight do I need to drop?
I have a bolt on car with a TSP Tv.2. It is currently an M6 but I have a RMVB, braked, freshly rebuilt TH350 with a TCI 4000 stall and a Cheetah shifter. I know 350s aren't the best with F bodies because of their weight but I was curious as to what I could pull and make it a streetable car? I have a set of GW Dragstars up front and a VFN hood. I have also done the ABS delete when I installed my Moser 9". Does anyone think this guy will survive leaving off the brake?
Old 01-19-2010, 08:14 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
This will give you some ideas
https://ls1tech.com/forums/drag-raci...y-updated.html
Old 01-19-2010, 02:28 PM
1badzo's Avatar
? dont understand the question at hand. So you are saying that a TH350 will add alot of weight to your car? It wont, it not being streetable, it will. I had the same setup as you are talking about and it was very steetable.
Old 01-19-2010, 03:18 PM
5_02ls1's Avatar
think he means the higher ratio 1st gear vs the lower ratio of the 60e.....with the verter you have and the brake i think you will be fine....
Old 01-19-2010, 06:48 PM
382ssz28's Avatar
Chevelles, Monte Carlos, Camaros, etc all weighed 3400-3800lbs. Most had 350's and were used and abused.
Quick Reply: TH350. How much weight do I need to drop?
