Where to mount B&M trans cooler w/ fan on F body?
Working on a single turbo 99 Trans Am with a TH400 conversion.
No room up front for the cooler. We have a killer B&M cooler with the spal fan attached.
There is room to put it behind the diff off the heat shield below the gas tank. I can put it there pancake style, but not sure if this is the best...and if I do, should the fan be on top or bottom.
There would be limited room between the tank and cooler.
need ideas quick!
need ideas quick!
There is simply no room up front for this unit. The intercooler, cooler pipes, relocated radiator, and pop up headlights eat up all the space.
