How much does a 4L60E weigh?
Old 01-03-2004, 12:53 PM
maddboost's Avatar
Default How much does a 4L60E weigh?
I was wondering how much a 4L60E weigh? Resaon I ask is Im going to probably pick a built one up in my buddies truck from FLP and then take it a few miles over to Speed Inc to have them install it along with my new engine. Could me and one other person move it. I then have to be able to take my old one back to FLP for the core charge.
Old 01-03-2004, 09:52 PM
Moderator
JNorris's Avatar
One person can do it (I did) but two will make it much easier.
John
Old 01-03-2004, 10:07 PM
Kumar 98Z's Avatar
if the converter is attached it would be a 2 person job, without one person could handle lifting it!
Old 01-03-2004, 10:15 PM
WILWAXU's Avatar
One person can do it.. but it's a handfull. Best to have one peron on each end just for safety's sake.
Old 01-04-2004, 02:44 AM
Jorday's Avatar
I can lift the 4L60E myself without much trouble when it's not under the car. When removing and installing, two guys makes it a lot easier
Old 01-05-2004, 12:10 AM
Pete2k_Z28's Avatar
Converter is around 50lbs (stock converter). Trans itself is around 120 I believe. Two is nice buy I never had a problem moving mine and I'm not a big guy by any stretch. Just pull the converter off first, put it upside-down over a bucket and let it drain as much as possible. Moving a trans with the converter in it isn't a good idea anyway unless you're using a converter strap.
Old 01-05-2004, 12:13 AM
The Guy in MY 99TA's Avatar
I can tell ya how much it weighs!!!
TO MUCH!!!!!!!!!!!!!!! GOD those damn things are HEAVY!
Josh S.
Old 02-01-2015, 12:27 AM
marceloos22's Avatar
Default it weights alought
Today I had a great Idea to bench press a 4L60e filled with liquid and torque converter on.
I asked my 7 year old son, if he was scared that it was going to fall on my. Sense I was making so much noise lol. He looked at me crazy, and said I wasent scared your muscles where scared they where shaking. Point being I did it! but that sh!? Is Fu <%€n heavy
The following users liked this post:
Nick King (10-06-2020)
Old 02-01-2015, 08:01 AM
01ssreda4's Avatar
John
This is correct.....converter removed obviously.
Old 02-01-2015, 10:13 AM
alowerlevel's Avatar
This thread is 4 years older than your son..........
Old 02-01-2015, 02:53 PM
Moderator
mrvedit's Avatar
To be precise, I measured a dry 4L65E at 133lbs, which might be 1lb more than a 4L60E:
Of course a converter will add 30-50lbs to that, plus about 10lbs for the ATF.
The Harbor Freight $145 transmission jack is decent. (Their $89 trans jack is NOT! Skip that.).
http://www.harborfreight.com/800-lb-...ack-60234.html
Here is mine:
$145 is a lot less than a visit to the ER and/or (seriously) injuring yourself or your buddy.
Old 02-10-2015, 05:01 PM
Super Hulk Smash
JakeFusion's Avatar
Agree. I've removed my trans a couple of times using the Harbor Freight jack. It makes it pretty damn easy.
Old 10-06-2020, 11:08 PM
Nick King's Avatar
I do agree is much easier as a two-person job but also have to say I just did lift one in there by myself torque converter and all definitely was a bear butt got it done! 😬
Old 10-07-2020, 08:07 AM
MaroonMonsterLS1's Avatar
Received 1,218 Likes on 782 Posts
@Nick King did you really just create a forum account, login, then use your first post to comment on an irrelevant thread from 2004?
smh
Old 10-07-2020, 02:30 PM
dixiebandit69's Avatar
Is it just me, or do we get a lot more of these necroposts on this board than the others?
Quick Reply: How much does a 4L60E weigh?
