th400 into 95' z28
Old 03-29-2010, 12:58 PM
805sElite's Avatar
Default th400 into 95' z28
so i am new to this site and the hole domestic buiding is fairly new to me but i know enough to get by but in this case i wanna be sure im not missing anything, i have a 95 z28 i am swapping in a th400 i wanna know if its straight forward or is there anything special i need to worry about other then the drive shaft and the Stall converter, i understand i will need to get a new drive shaft and the stall is for the th400 . but other then that any info would be grately apprieciated. thanx again
Old 03-29-2010, 01:11 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
these should help out
https://ls1tech.com/forums/automatic...questions.html
https://ls1tech.com/forums/automatic...th400-faq.html
Old 03-29-2010, 11:13 PM
805sElite's Avatar
thanx alot those were both alot of help.
Old 03-30-2010, 11:11 PM
big block camaro's Avatar
i got a stock six speed crossmember in mine and had to re drill hole 3/4 inch back farther
