Difference between LS1 and LT1 4L60
i not sure what the differences are between them, my tranny just went out in my Lt1 camaro and i have access to a LS1 4l60 tranny out of 98 camaro, are they enterchangable?
Unfortunely I think I am getting to learn the difference. I have an LS engine and trans and ordered an LS converter from PI. Looking down the center of the converter I see two splined sections and below the second splined section is a reduced diameter smooth section. I am thinking the LS converter bore should end at the second splined section as the input shaft is splined to the end. Assume the input shaft on an LT has a small smooth section on the end. Also taking measurements the input shaft on the trans is 5 5/8" to the pump and the converter is 5" to the bottom of the second splined section. Does this sound right?
the convereter and the pump and the input shafts are different, the lt1 4l60e has a smalleer stator than the ls 4l60e
__________________
https://ls1tech.com/forums/image.php...ine=1194732633
Free Cooler, Free shipping always, 2 year warranty Trans/Coverter combos, No Core or Core charge, $150 LS1 core buy back, All trans Dyno Tested to Be sure it works when you get it.Customer videos, Tech Thread, Open 7 Days a Week! Call or http://opi.yahoo.com/online?u=performabuilt&m=g&t=2Click Banner for Website.
Not Just Built.....PerformaBuilt!
Can someone post pictures of the different input shafts? Or at least the correct one for the LS1 4L60e?
I have a 1999 late 4L60e from a 1999 Astrovan 4.3 (I think) and I was wanting to put it behind a 2004 vortec. I need to make sure this combo will work as is or if I need to do some adapting.
well craps, I'm going to have to do some adapting to make mine work I think. I've attached a picture of mine.
It is adaptable isn't it or do I have to start over with another tranny?
