4l60e bellhousing filling up with tranny fluid!!!
Old 05-02-2010, 12:08 PM
adam`'s Avatar
Default 4l60e bellhousing filling up with tranny fluid!!!
my bellhousing is collecting fluid and coming out the inspection hole. does anyone know what needs to be replaced? keep in mind the bellhousing LEAKS when sitting and when running. the car sat in the driveway and leaked a good 5" diameter circle. i pulled the transmission out last night and cleaned all the fluid....
here is what she looks like right now. im thinking the convertor seal "part number 3227" made my timken?
http://www.autozone.com/autozone/cat...&parentId=12-0
Old 05-02-2010, 01:27 PM
LS1Tech Sponsor
performabuilt's Avatar
I would replace the front seal and pump oring along with bolt washers. I would als inspect the converter hub for cracks or wear
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 05-02-2010, 01:33 PM
BrianC98Z28's Avatar
What Frank said
Old 05-02-2010, 04:38 PM
adam`'s Avatar
do you happen to know part numbers for the front seal and pump oring? i dont see how the pump would be leaking unless under pressure. anyway, i would rather get everything done now instead of taking the tranny back out next weekend. some people say to replace the pushing behind the pump so if anyone knows that part number as well it would be great!
Old 05-03-2010, 07:17 AM
72blownvert's Avatar
While you have the trans out you should also check the pump bushing & replace if needed.Did you shim the converter properly?1/16 to 1/8
Old 05-28-2010, 01:48 PM
adam`'s Avatar
ended up being a cracked neck on the coverter.
Quick Reply: 4l60e bellhousing filling up with tranny fluid!!!
