Shifter button...
Shifter button...
So, I was putting the Z's A4 into gear when the shift button "pops" out and flies somewhere outside of the car. Minutes later I find the spring, the shift button and some other pieces of plastic, but now I can't shift the car. Have any of you dealt with this before? I don't see how I could fix this properly without removing the whole shifter assembly. How far does that white plastic rod go into the shifter? How do I replace/fix it? As of this writing, I'm shifting by sticking a pen into the shifter itself, simulating the presence of the shift button that's now broken off. You guys have any ideas on what to do with this? Thanks in advance...
