m6 to a4 now car wont start
98 TA went from m6 to a4 but wont start. no spark or inj pulse
I running a a4 wire harness and a4 pcm and tuned for vats. It will crank but no start
did you have the engine out of the car?
start with checking all the grounds.
did you make sure the neutral safety switch is wired correctly?
any fuses blown?
did you use a 98 wire harness?
I hope you can figure it out man, im in the middle of a tranny swap as well....
any fuses blown?
98 harness, all gounds are in there place
need to go over the neutral safety switch but I dont think it would change anything
i did have one blown fuse dash lights.
