RMVB shifter for 4L80????!!
Old 06-14-2010, 08:25 PM
1BADWS6@STENOD's Avatar
Exclamation RMVB shifter for 4L80????!!
I'm having my 80 built with a rmvb...problem is I can't find a shifter! Is the shifter for a 80 the same as a 700r4? That's the only 4 speed gm shifter i can find in a reverse pattern. If I can't find a shifter...i'll have to hurry up and let my trans guy know to make it a forward pattern. Thanks for the help!
Old 06-15-2010, 06:25 AM
Photochop's Avatar
https://ls1tech.com/forums/automatic...fmvb-4l80.html
He beat you to it.
Old 06-27-2010, 07:42 PM
I need a shifter for a Reverse manual valve body....can't seem to find one even for a 4L60!!! He asked for on for a FMVB
Old 06-27-2010, 08:40 PM
FLT
FLT's Avatar
Maybe contacting the manufacture of the valve body will yield you better results. I would think that a shifter for the 700 would work fine however you will need to fabricate the brackets for the cable at the trans in order to make it work. Vince
Old 06-27-2010, 09:18 PM
Fabricating is not a problem! As long as it has the same gear spacing, I can make the rest work
Old 06-27-2010, 10:13 PM
Photochop's Avatar
You may run into issues with the linkage bracket to the trans and/or the shifter cable bracket that mounts to the trans. Valvebody whether reverse or manual shouldn't matter.
Old 06-27-2010, 10:48 PM
jakeshoe's Avatar
The reverse manual or forward only matters if it is detent shifter and not a ratchet type.
The internal linkage (detent spacing) stays the same on either type of VB.
My experience with the 4L80E vs. 700-R4/200-4R compatible shifters is that the low gear (4th with a RMVB) position is further away, so you usually need to alter the angle of the shifter lever on the side of the trans. It goes too far back and when you try to come out of low it will bind because you are pushing in almost a straight line.
Old 06-28-2010, 03:24 PM
kevin87turbot's Avatar
I like the TCI Outlaw shifter with their reverse pattern 4 spd gate plate. The Outlaw shifter is part number 611523. The gate plate is 618018.
Quick Reply: RMVB shifter for 4L80????!!
