Changing Trans fluid 700 miles after rebuild?
Ive heard this before but wanted to confirm, ive got a fresh 4l60e in my car and its now been broken in and has 700 or so miles on it. My question is, is it a good idea to change the trans fluid now that its broken in? from what ive heard the new clutch bands will create a little bit of debris. If anyone can share their thoughts on this it would be appreciated.
You don't need to change the fluid if it is fine (which it should be and would be a waste of money) but change the filter only if you insist. Look at the bottom of the pan away from the magnet and see if there is any clutch/band material, and check out what is on the magnet. If you see anything that you are not sure of, take some pictures and post them.
