converter question
Old 10-21-2010, 02:15 AM
FARMER's Avatar
Default converter question
I have a cam only 01 z28 with a vig 4100. BESt pass was 1.56 60ft.11.68 @ 113. THat seems a little low in mph to me. Would I be better off going with a yank ss4000. Any advice on this?
Old 10-21-2010, 04:45 AM
Mac 2002 SS's Avatar
Well it's obvious that your Vig is working just fine with that 1.56 sixty . If you want more mph , just add a set of good flowing heads on your car since you already have a cam. I wouldn't change converters if I were you.
Old 10-21-2010, 11:03 PM
Quick Sh0t xMLx's Avatar
Well your car is running pretty good. That low of a 60' tends to reduce your trap a bit. Like the previous poster said I wouldn't bother switching converters as it's obviously working well. Maybe a little nitrous
Old 10-21-2010, 11:24 PM
FARMER's Avatar
I guess ill try it for a little longer. I like the way it works and feels in normal driving just heard some negative feed back on Vig converters as far as mph.
Old 10-22-2010, 01:23 AM
01ssreda4's Avatar
With a converter change, if you gain any in mph, you will lose it in 60 ft times IMO. So what are you really chasing? E.T.s or MPH?
Old 10-22-2010, 03:20 AM
SSmoken's Avatar
id keep that converter and buy something else. i ran 11.6x's @ 113-115mph before.
