different size cooler lines
Old 11-01-2010, 09:26 PM
themack56's Avatar
Exclamation different size cooler lines
what happens if i use different sized cooler lines?
like if i use for the top or bottom the truck style lines whcih are bigger and the other hole with the fbody line, which is smaller.
any issues that i would run into?
Old 11-02-2010, 09:45 AM
senicalj4579's Avatar
From what I understand bigger hoses help combat excess TC pressure which in turn decreses premature thust bearing failure. I would think that you will be fine but im not a trans builder
Old 11-02-2010, 10:04 AM
01ssreda4's Avatar
They have a prefab braided stainless line kit on ebay for very reasonable price.
Old 11-02-2010, 07:41 PM
FastKat's Avatar
As long as both of those lines are at lease 3/8", you should probably be okay.
