LS1 flexplate on LQ4 6.0?
Old 12-31-2010, 09:26 AM
Earl Filter's Avatar
Default LS1 flexplate on LQ4 6.0?
I have a 2004 LQ4 6.0 that had a 4L80E behind it (it was a 4x4). I have a new style 2WD 4L80E, and a Vigilante 4L80E converter that is made for LS1/4L80E swaps, so it has the 3 mounting pads like a 4L60E, but goes into a 4L80E. Now I want to use that converter, but it won't go to my flexplate with 6 holes that was set up for the 4L80E. Can I put a stock LS1 flexplate on the LQ4? I shouldn't need any spacers, right?
Old 12-31-2010, 10:23 AM
Gingervitis Addict
slow67's Avatar
Yes, that will work fine with the ls1flexplate.
Old 12-31-2010, 12:20 PM
forcd ind's Avatar
make sure to rem the spacer behind the 4l80e flywheel-it looks like part of the crank, but should have 2 threaded holes to aid in rem it
the stock crank sticks out about 1/8" past the seal, and the spacer another
.400
Quick Reply: LS1 flexplate on LQ4 6.0?
