Electrnic Speedo Help Pls!
Old 03-15-2011, 08:25 PM
Swerve7rpm2000's Avatar
Default Electrnic Speedo Help Pls!
Ok guys i have a 4l80e and an Autometer electronic gauge w/ a 2002 truck computer and harness..... From the computer i have used Vss, Low Vss, High Vss.... The only one that gave my speedo a signal and made it move was High Vss, but when i was connected to it the truck wouldnt shift into 2nd, 3rd, or 4th gear.... Unconnected it and everything shifted fine. Is there a way to make this work? Couldnt come up with anything under search, Thanks for any help
Old 03-16-2011, 06:31 PM
Jays_SSZ28's Avatar
The VSS signal goes into the PCM, theres a VSS out or speedometer signal for the speedo. You need to try that wire. I'm not sure if it outputs a signal compatible with the gauge though.
Old 03-16-2011, 08:48 PM
It dosent work, that would be the Regualar vss signal which is drk green/white and is pin# 50, they give me this wire loose to tie into my speedo but it wont work, wonder if i can somehow program this signal through hp tuners
Old 03-16-2011, 09:11 PM
ne one else ever ran into this?? I have a autometer gauge and 4l80e
Old 03-16-2011, 11:22 PM
Jays_SSZ28's Avatar
Contact Autometers tech line.
Old 05-23-2011, 10:31 PM
Sent this speedo off to autometer and they told me it was bad so they sent me a brand new one! Still the same problem.....Any suggestions?
Old 05-31-2011, 02:12 PM
streetrodmuscle's Avatar
I just connected a Autometer speedo to a LS1 from a Camaro 2002. You need the pin 50 green/white wire. It is an output from the PCM, so just cut it and splice it into your VSS wire to the Autometer.
You will not see the speedo move until you've done the calibration according to Autometer.
1. Keep the trip reset button pressed in while you turn the key and start the engine. Hold it until the speedo goes fully out.
2.Release and drive to the start of the 2 mile stretch you have figured out on Google maps (for example). Do not switch off the ignition!
3. Come to a standstill at the start position and press the reset button again. The speedo will go to half.
4. Drive the 2 miles. You may stop, drive hard, drive slow, whatever you like.
5. When you come to the end point, come to a standstill and press the reset button again. The speedo goes to 0.
You are now calibrated and ready and as you drive off, it should show the correct speed. Mine did!
The accuracy of the calibration depends on the accuracy of the 2 miles measured up and travelled.
Good luck!
