will a 4l60e that was in a LT1 car work on my 98 Trans am??
Moderator
Anything can be made to work however I would look for a unit that is correct for your car. The issue you will face with the other trans you have mentioned is that the converter does not have the correct pilot on it and it would create an issue with the support of the converter. Also you might run into an issue with the cross member and the torque arm. You can get basically any 98 and later LS1 60e and install it with much less work. Keep in mind if you find one out of a truck you will want to swap the shifter linkage and the 2nd gear servo. From there you would just need to swap your tail housing and you will be good to go. Vince
