4l60 needs replaced in my 93 i think help?
Old 04-04-2011, 08:41 PM
redtransam95's Avatar
Default 4l60 needs replaced in my 93 i think help?
sometimes it shifts great other times i take it out i pretty much have to manully go though the gears. will a normal 700r4 work or do i need a 4l60 for a 93? or does someone have an idea of whats going on?
Old 04-04-2011, 08:46 PM
raidernation3017's Avatar
Has to be a 4l60e
Old 04-04-2011, 09:17 PM
no 4l60 its a 93 none electrc 5 wire
Old 04-04-2011, 09:37 PM
LS1Tech Sponsor
performabuilt's Avatar
You can adapt the 700r4 to replace that unit as its really just a 700r4 with a couple presure sensors added which when missing will not in fact set a code. You will have to change the round plug to a square one on the cars harness and make some changes in the internal trans wiring or not depending on where the trans comes from.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 04-04-2011, 09:57 PM
ok helpfull i guess vgue but nice to know
Old 04-05-2011, 01:04 PM
LS1Tech Sponsor
Well in our case we ship the units set up so its as simple as making sure there is power on PIN A and it will lockup anytime you get into 4th gear. But when your looking at stock replacements there are several different wiring variations so its hard to be more specific.
__________________
Call 888-744-6542
