3 converter bolts - enough for 1000HP with transbrake?
I had a talk today with Chris from circle D and he told me that the CSR is not a drop in piece, he said it does require some kind of spacer,,EVEN WHEN USING A 4l60 trans and converter. Just to share what I learned,, Personally I am going to go with the HUGHES it has a wieght of6.58 lbs, iTs sfi rated, stamped steel, and about 160.00 and is a direct drop in flexplate, no spacer worries or anything like that. Look em up on Circle ds website. As to where the CSR is about 5.5 lbs and 300$. If you have not bought one yet here it is
http://www.circledspecialties.com/p-...lex-plate.aspx
When I researched about flexplates recently, I thought Hughes steel plate is much more than 6.6lbs. IF it were only 6.6, I would buy it instead of CSR.
I don't see why CSR needs a spacer... I'll check engagement with starter teeth once again but can't see any problems
