700R4 help with electronic speedo sensor
I bought a rebuilt 700R4 from a reputable builder but have been unable to reach him for my question. When I picked it up, he told me he installed a electronic speedo plug which I saw but he said the "gears" were out of stock so they're not in there. I thought the plastic gears were used on mechanical speed sensors. Anyone have any idea what he was talking about and what I need to purchase?
Thanks,
Jeff
Thanks,
Jeff
Moderator
Depending on the year some of the early electric VSS systems used a plastic drive gear on the output shaft and a plastic gear for the driven gear on the sensor. This is what he is talking about. If you have the means of posting a picture of the VSS plug he installed a I could confirm this for you. Vince
Vince,
Thanks very much for your help. It came from a early 90's LT1 Camaro, I think a '92. I really appreciate it. The pic is a little blurry but I hope you can see it. If you could just let me know what I need, where to buy it, and kinda walk me through how to put it on?
Jeff
Jeff
Moderator
Jeff with that style sensor you need a VSS rotor not a gear. The issue here is normally you would press the rotor on the output shaft before installing it in the trans. Let me see if I can find a part number for you.
700r4, 95, electronic, gear, head, mechanical, plug, powerglide, sender, sensor, speedo, speedometer, trans, transmission, vss
