Mixed up the trans lines.. Help..
I think i've swapted the lines.. Theres 1 comming from the bottom of the radiator and 1 comming from the top.. Does the bottom line go to the bottom port on the trans or the top port ofthe trans? As of now i have the bottom line going to the bottom port and the top going to the top.
From what I remember and can see in the manual your description is correct the way you have them. Honestly as long as the fluid flow forms a loop from the trans, thru the cooler and back into the tranny it's fine.
