12" 3200 stall?
Old 07-18-2011, 05:30 PM
thebufenator's Avatar
Default 12" 3200 stall?
I have a stall in my garage that is a 12" diameter and the only markings are:
65106
3200
Any idea what it is? I have a stock diameter 2800 stall in my LT1 that the previous owner installed, is a stock sized 3200 a bad idea?
Old 07-18-2011, 08:53 PM
LS1Tech Sponsor
performabuilt's Avatar
That would be a very inefficent converter and make alotta heat.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 07-19-2011, 12:32 AM
01ssreda4's Avatar
Yep, in a stock size you can only push them to about 3k/3200 from what I've seen. You need to reduce the diameter to run the higher stall speeds.
