bolting converter to flexplate?
Old 07-21-2011, 06:13 AM
Justins00ss's Avatar
Default bolting converter to flexplate?
Ok iam finishing up my th350 swap and was wondering if I just bolt the flexplate to the converter or do I use the bolts and put a nut on the other side.
Old 07-21-2011, 06:49 AM
Detroit Gearbox's Avatar
Depends on the converter. Some have threaded "lugs" or pads, some have just pads and require a nut and bolt.
Old 07-21-2011, 06:57 AM
Mine has threaded pads. So I don't need a nut on the end?
Old 07-21-2011, 07:46 AM
Circle-D's Avatar
Correct, if it is threaded just need bolts....
Chris
Old 07-21-2011, 08:27 PM
senicalj4579's Avatar
Make sure you measure!
Old 07-22-2011, 08:18 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I spaced my converter an 1/8" away from the flexplate, fwiw
