What are these gaskets called?
I am putting a pump in my 4L60E and the gasket kit came with everything but these hard plastic type o-rings. Anyone know what they're called or where I can get em? I thought maybe I could reuse the old ones but as soon as I took them off the old pump they stretched, and are unusable.
(The 2 o-rings highlighted)
Stator support rings, and they make a tool to install them. (expands and compresses them properly). Always check the fit to the reverse input drum on the bench before you reinstall the pump.
