1993 TA with 4L60 problems
Old 08-02-2011, 09:31 AM
slow93ta's Avatar
Default 1993 TA with 4L60 problems
I have a 1993 TA with Vortech supercharger, longtube headers, hot cam, 410 gears, and a bunch more bolt ons. I just bought a Level 3 4L60 not E from Mad Dog Transmissions. I finally got it installed and and the trans goes from 1st to 2nd around 5 mph and it seams to shift fine in each gear but it does not kickdown when I floor it, and it feels like the car has about half the power that it did with the stock transmission. Please Help. Any suggestions!!!
Old 08-02-2011, 09:56 AM
Heads-Up-Outlaw's Avatar
It sounds as if you need to take a very close look at the Throttle Valve Cable adjustment.
How did you adjust it when you installed the transmission?
Old 08-02-2011, 01:28 PM
slow93ta's Avatar
I just unhook the cable from both ends and left it hanging there until I put the new transmission in, and then I just hooked it up like it was on the old Transmission.
Old 08-02-2011, 02:00 PM
lt1-xjs's Avatar
Changing the trans will require a readjustment of the t/v cable.
Old 08-02-2011, 02:13 PM
slow93ta's Avatar
Thanks!! Another issue i,m having is the gear selector cable will pull the trans out of park, but will not put it back into park. If I pop the cable off it will click into park. Any suggestions?
Old 08-03-2011, 09:31 AM
The cable housing should have an adjustment near where it mounts to the transmission. Google that and see what you can find... if you need help shoot me a pm and I'll walk you through it.
Old 08-03-2011, 09:47 AM
Mystery Bird's Avatar
Here is a write-up to properly adjust the shift cable. http://shbox.com/trans/A4_trans_linkage.html
