How to chose stall speed?
Combination,
1986 Camaro
5.3
Ls1 heads
Cam 204/218@.050 .551 lift 112LSA
Truck manifolds
T76 turbo
4l80E transmission
Trans brake
3.50 rear gear
28 inch tall tire
Running E85 and looking at about 500-600 wheel hp.
I was kind of leaning towards 3600 stall. But looking for any input.
1986 Camaro
5.3
Ls1 heads
Truck manifolds
T76 turbo
4l80E transmission
Trans brake
3.50 rear gear
28 inch tall tire
4000 get that turbo to spool and letter rip.
but really i would call some of the larger builders and talk with them. you are going to probably get a few different responses.
like mine.....
like mine.....
I think 3600+ will be a good range. Make sure you will have no problems spooling it. Getting something custom built for your setup is highly recommended. Turbos are probably the hardest combo to build for. I would also suggest a multi disk, so you can lock up on the big end and load the turbo....
Chris
Chris
