How can I figure out if I have a manually valve bodied th350?
Old 09-02-2011, 02:41 PM
6erWebb's Avatar
Default How can I figure out if I have a manually valve bodied th350?
I bought a drive train from a mutual friend who said it was a rebuilt 406 and manual valve bodied trans. After the 406 turned out to be a stock 400 with egg shaped cylinders and smoked bearings I have my doubts about the trans.
I know I need to remove the pan and then the "valve body" itself, but I dont know anything about autos so Im sort of lost. The trans shop wants 100 to tell me whats up but I have the skill I just dont know what to look for.
If anyone can help Id really appreciate it.
Old 09-03-2011, 08:16 AM
Moderator
Vince B's Avatar
Well thats kind of an open ended question because there are a few ways to have a manual vb in these units. Is this supposed to be a forward manual vb or a reverse manual vb? Is this trans running a modulator?
Old 09-03-2011, 08:33 AM
Mattsv8's Avatar
does the tranny shift in drive? if not its a manual valve body.
Old 09-03-2011, 09:04 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
If the modulator valve isn't hooked up then it won't shift either if left in drive
Old 09-03-2011, 09:47 PM
6erWebb's Avatar
Well first I should say Its not in a vehicle, I bought it and never did anything with it. AND Im not exactly sure what its supposed to be, all I was told is that it was built so that you had to shift it from first second and third manually. But Im not an auto guy so I dont know what to look for.
