700r4 converter in ls1 and 4l60e
Old 09-07-2011, 11:20 AM
jak2908's Avatar
Default 700r4 converter in ls1 and 4l60e
i was told that this can be done with no modifications, just as long as it is a 30 spline converter...i have a b&m 3000 stall converter for a 700r4 and im sick of it sitting around
Old 09-07-2011, 02:42 PM
lt1-xjs's Avatar
The 700r4 and lt1 4l60e's 30 spline are the same, although I think the ls1 has a longer input shaft and it will not work.
Old 09-11-2011, 01:27 PM
Pocket's Avatar
The converter nub is shorter so you'll have to use the crank adapter from a 4L80E
Quick Reply: 700r4 converter in ls1 and 4l60e
