3600 stall went great...then i got home
this weekend my cousin, buddy, and I went ahead and installed the new 3600 revmax torque converter. Everything went smoothly and drove nice on our first 2 mile test drive. Once we cleaned everything up I drove home, stopped at a gas station and noticed a nice puddle of motor oil dripping on the floor...drove home and checked again now it was all over the trans/engine/rear end...
i also installed a new rear main seal and the round seal where the flywheel bolts down to...
we didnt use any rtv silicone around the seals...is that needed?
Any advice or tricks you can think of would be greatly appreciated im anxious to drive this thing
Hmmm I doubt its the oil press. Sender behind the intake...so no rtv on the bottom lip where the main seal meets the oil pan? Also the round seal had a plastic center does tgat come off?
Restricted User
Im not sure about revmax, but I was told by Chris at Circle D to put mine in and give it hell! And I did. I made sure my fluid was all good and everything was working nice and than I did a 1/4 burnout lol. My converter is working very nice
I checked the fluid, drove around the block, checked the fluid again, pulled out onto the main road and went WOT!
Thats sucks i crossed my fingers when i did mine after hearing stories like this.
So you pulled just the seal not the rear cover? Made sure the seal wasnt installed
backwards? I added form a tad of for a gasket where the rear cover meets the oil
pan and on the od of the seal. I used a fel -pro seal and i accindently remove that
white plastic so i just put back on and bottomed out the seal onto the cover.
Make sure the crank area is clean i wiped mine with some gas.
Pretty sure the plastic insert is just there to hold the lips of the seal inplace while the seal is being installed (a guide while you slip the seal onto crankshaft.)
Well me and turygls1 took out the trans and redid the seals and afded a bit of.rtv on the bottom edge that meets the oil pan...put everything back together and drove it back home..so far so good not one drip
So now you ready to start the show!!!!
So you recommend Turygls1 as a pretty good mechanic ? I live near him I might need some help on some stuff ..inbox me his#### thanks.
