Small leaks at trans cooler - what can I do?
Hey guys. I have a b&m cooler with the 1/2" NPT threads [can't remember exact model]. It has a small leak at one of the adapters. As it stands right now, it is stepped through a few adapters to make it work. I got some new 1/2" NPT to 3/8 barbs I am going to be putting in there to see if that will help. That way it will be just cooler directly to hose not cooler > size adapters > hose.
Is there something I can put on the threads either before or after install to make sure it doesn't leak this time around?? I'm hoping it was just leaking at the adapters rather than directly at the cooler. Should I use some teflon tape or maybe a certain kind of RTV? Let me know what you think. Thanks!
Awesome. I'll have to look into that. Hopefully when I get rid of all the size adapters and just have the 1 fitting it won't leak but who knows. I'll see about buying some of this sealer before I tackle the project. Thanks!
