need help with my 4L60 ls 1st gen swap
Old 11-18-2011, 08:27 PM
s10pro's Avatar
Default need help with my 4L60 ls 1st gen swap
68 camaro gm crate ls6 with 4l60. the 4l60 has beast sunshell, corvette servo, hd 3-4 cluth and transgo hd shift kit red 2and gear band. with yank 3600. just took car up street for first time and it felt like it didnt wantg to shift let out then when i got back into it felt like it was in neutral . so i didnt want to push it. Any ideas ? going to tuner tomorrow, Hope its in the ecm tuning. also forgot to metion i have a lokar dipstick maybe the trans dipstick is reading full and its not ? thanks for your help, kevin.
Old 11-19-2011, 05:52 PM
Moderator
Vince B's Avatar
It sounds like your issue might be in the tuning. What are you using to control the trans? Also do you have a VSS and a TPS signal set up for your controller?
Old 11-22-2011, 08:08 AM
s10pro's Avatar
trans is controlled off ecm , not getting signal to vss any ideas
