4l60e, pwm or not?
4l60e, pwm or not?
I have a fresh built 4l60e but don't know if its compatible with a 5.3 conversion. The trans # 3WSD1010 and has PWM on the pump plate. I looked up the # and it seems to be a 93 but then I read the pwm was put on 95 and above pumps. It has a 12 pin connector on pass side also. Can it use this with an 04 harness and pcm, for my 5.3 conversion?
