4l80e yoke recommendation
Can anyone recommend a yoke that will work with this output shaft?
The output shaft is fully splined, and the cup you see has an o-ring in it that seals on the outer diameter of the yoke.
I shouldnt need a counterbored yoke right?
try the Slip yoke that TCI makes...
Part # 965350
its actually labeled as a TH400 1350 Yoke on their website...but its the same thing for a 4l80
definitely call them to verify.. they may want some measurements to verify...but the one I listed works for most 4l80's
they also have one with a 1310 if you want it....
Part # 965350
