Rubber seal on rear of 4l80e
Old 02-11-2012, 11:27 AM
Tire Smoking Tranny Blowing Director
Cool28's Avatar
Default Rubber seal on rear of 4l80e
When you put the yoke in does it get pushed in or stay out?
Old 02-11-2012, 05:19 PM
Gilbert@Ace Racing's Avatar
Which seal are you referring to? The extension housing seal or the seal on the shaft itself?
Can you get a pic up to clarify?
g
Old 02-11-2012, 05:38 PM
Cool28's Avatar
It's a rubber seal that comes out at the end of the case. It's like 1inch wide piece of rubber.
Old 02-11-2012, 05:43 PM
Ohhhh okay, that is the dustboot that is attached to the seal itself.
It's not abnormal for it to compress a bit when the yoke is installed. As long as it's not mashed completely to the end of the tail housing you should be fine. If it is, then i would be concerned about the length of the driveshaft.
g
Old 02-12-2012, 11:50 AM
Cool28's Avatar
Ok thanks ya its compressed but I can still push the yoke in alittle more by hand
Old 02-12-2012, 05:14 PM
That's good. The key is that you do not want the yoke to bottom out when the suspension is being exercised. That is a bad thing!
g
Quick Reply: Rubber seal on rear of 4l80e
