Shift Kit or Electronic Shift Kit
Guys I just picked up a 2000 Camaro SS, and it's automatic. I would like to install a shift kit, but since this is an electronic transmission I need to ask this question because I'm use to old school Th350s and 400s. What would be best for a traditional shift kit, where you knock down the valve body, or an electronic unit that you control by the push of a button, or both?
http://www.summitracing.com/parts/BMM-70365/
Or this
http://www.summitracing.com/parts/TCI-377550/
Or Both?
Or this
Or Both?
There are 'kits' that help improve the performance, but you'll find a lot more support for the TransGo HD2 kit around here.
Being in Oakland, CA, you should be able to find a good local tuner that can do many things thru the laptop tuning.
Read, Read, ..., & then read some more.
I'm not a transmission guy at all, but I don't recall see many threads with those types of programmers around here.
Even tho I did stay at a Holiday Inn Express last night, ...
Read up on converter swaps. You'll see a huge improvement in response/performance.
Dont mean to hi jack but im in the samem boat and does the HD2 shift hard under normal conditions? I dont want something thatll break your neck while driving normal with the wife in the car lol.
Not hard at all. The instructions are pretty clear, and some springs you don't use. They're just included to cover all the design changes inside the valve body. I'd say R&R of the valve body is a bigger pain than installing the kit.
