I have a 2 wire hipster trans brake on my th400. can I just put one wire under this bolt like I just did for a ground? does it matter which wire is the ground? they arnt marked.
Is there any need to run a ground strap from the case to the frame rail? I have seen some race cars that actually had a ground strap from one of the bolts on the tail shaft and then bolted to the frame rail.
