4l60e Problem.
4l60e Problem.
So I went to take my car on its first drive today after the lt1 swap and after putting it in gear there was no movement at all. I tried every position on the shifter (including reverse) and nothing. Previously during the day on the jack stands we tested it with no wheels on it and it rotated in d and reverse, but it seems under weight it wont move at all. I took off the upper trans cooler line from the radiator and there wasn't anything flowing out. Does anyone have an idea what is wrong?
For reference it is a motor/trans from a 97 z28 that was driven into my garage before I began the swap, so I know the trans was working. I also deleted cruise control and acr, but I do not believe that would have an effect on the gears engaging.
I'm having a similar issue...I'm subscribing to see if anyone can come up with any good ideas.
Right now I'm trying to see if I put in enough fluid. Also wondering if I "have" to have the little gearshift selector plugged in (it currently is not). Talking about the little black thing that bolts on over the shift lever.
Good luck!
Good luck!
Maddogtransmissions
Hello boss man, whether it is a 700R4 or a 4L60E it should still engage with no electronics whatsoever either you broke the front pump or you do not have enough transmission fluid.
Please contact me for a professional consultation regarding your needs. We are happy to provide you with references both here in the United States and Internationally. Be sure to check out our website at maddogtransmissions.com
Hear what our customers and fans say on our Facebook Page at www.facebook.com/maddogtransmissions
We also accept orders over the phone. Be sure to contact us and we will recommend the correct transmission for your application. For your convenience, we accept PayPal and all major credit and debit cards.
If you prefer, we can call you personally, just e-mail us your phone number.
All our transmissions are very strong and reliable, and can be used for everyday driving. Extended warranties are also available.
Thank You,
"Mad Dog" Lou
Mad Dog Transmissions
Phone 770-781-0949
Fax 770-781-0969
Web: www.maddogtransmissions.com
Facebook: www.facebook.com/maddogtransmissions
Twitter: www.twitter.com/maddoglou
YouTube: www.youtube.com/maddogtransmissions
Thank You,
"Mad Dog" Lou
Phone 770-781-0949
Fax 770-781-0969
